quadsean1
Anyone know the biggest paddle track I can fit on a 2006 apex with 9 tooth drivers? Also I have ad bovin suspension and a cr 144 tunnel.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
1.5" with the track protection in place
chiefsledhead
If you go with 8 tooth drivers and remove the tunnel protectors, you can go with 2 .25. If you are going to a paddle , even at 1.5, you need anti ratchet drivers. Since you need to change drivers, go with the 8 or 9 tooth that gives you the ability to get the paddle height you want. Depending on how much of a change you make, you may need to change your gearing to match.
I went with 8 tooth and 2.25 back in 07 and haven't regretted it one second.
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
So i can put a 1.5 on a stock attak ?1.5" with the track protection in place
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Yes
snobill
- Nov 4, 2012
- 2012 apex xtx
thanks thats what im gona do when the track wears out
snobill
- Nov 4, 2012
- 2012 apex xtx
Can you stud it ?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Yes but I didnt
snobill
- Nov 4, 2012
- 2012 apex xtx
nice thanks !
