saskieXTX
- Nov 24, 2015
- Saskatoon
- 2015 Yamaha SR-Viper XTX
1997 Yamaha Vmax XTC 600
I'm thinking of adding a rear seat and am wondering if a second set of hand warmers would draw to much and blow a fuse? I'm also thinking of putting the circuit on a quick connect like my helmet visor. Thoughts?
Sent from my SM-G900W8 using Tapatalk
DC5
The OEM yamaha 2 up seat has handwarmers on it so it should be fine.
Team Lazy
- Jan 22, 2016
- Barrie
- Viper XTX
Bravo 250
https://secure.2mmotorsports.com/en...wmobile-cargo-box-arctic-cat-procross-99rk560
Also fits Yamaha. Has heated hands and rear LED lights, as well as a storage box big enough to fit a helmet.
bbquadrider
- Jan 22, 2014
Wouldn't bother as the grips are a poor place to hold on...safer and better to place hands on the driver.
via big bad phone
via big bad phone
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
Installed RTK seat with handwarmers, used accessory plug near chaincase, no issues with fuses
saskieXTX
- Nov 24, 2015
- Saskatoon
I already used that accessory plug for a helmet plug. Wonder if it will handle both.
Team Lazy
- Jan 22, 2016
- Barrie
- Viper XTX
Bravo 250
If you buy the plug and play connector from Rocz it has 2 helmet connectors and 2 USB charging points, plugs right into the back of the existing 12v jack using factory connections. Then you would have that accessory plug open again while being able to charge a GPS and cell phone.I already used that accessory plug for a helmet plug. Wonder if it will handle both.
