riverrat
Can you see over the bars to view gauge with 2" riser from Rox?
06RTXTASY
I didnt put the rox riser on but I did put on the powermadd 4" with pivot adapter which raised the bars about 2". I have to kinda give the "chicken neck stretch" to see it but i can see it sitting.
leaddog
Nope
monsterattak
depends on how tall you are..... i am 6'4" and i can see the dash with a 3" riser......not as good as before but doable.....
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I have already mounted my gauge higher in the light pod.
Some shop mentioned in a thread a couple of weeks ago machines a bracket for $35 to relocated the gauge on the handlebar riser a la the Phazer. I am planning on doing that but am a little reluctant to mess with the wire harness.
welterracer
that dends how far forward you sit..
If i sit all the way forward like i do in the twisty trails than YES i can see th guages..
If sitting back i cannot.. I am 5'8 tall
I had a 2" pivoting Rox riser and I am 5'11". Not a chance of seeing it.
mdkuni
I did not even think about this. I actually just put on the Rox Riser this weekend. I went and checked it and I CAN see the guages right now as I do not have the pad on. As soon as I put the pad on I can only see the guages if I am standing up or sitting up front. I am 5'8".... Looks I will be riding without a pad from now on. I look at the guages a lot so there is no way I could stand not seeing them.Similar threads
