Carbide Recommendations
mcamzr
Armada MI
I think I need to down size my carbides on my Nytro. The longer I ride the more you need to be a gorilla to turn it. My set up is currently 9in shaper bars on C&A Razors, 50psi in the floats, stock121 ripsaw no studs, front straps full loose, rear strap is one hole from full loose, and I want to say 4 or 5 threads showing on the center shock. Though I can rail corners like this I know it could be a lot better and id like to see what everybody thinks. I've just always been shy of going to a shorter carbide since the turning has never bothered me on any sled before. Thanks for the help. Mike.
