TRiGGeR605
Will setting it on the hardest setting decrease ski pressure or increase ski pressure?
My objective is to get the sled to behave aggressively. I like a lot of weight transfer and for the sled to feel alive. This is my second nytro and both nytros came stock on the softest settings for all shocks which in my opinion made the sled feel heavy and lazy.
My fix on the first sled which had clickers was to max out the weight transfer and adjust the clickers. However on my new to me 13 1.75 I dont have clickers. So far I have set the front shocks on stiff, fully lengthened the limiter straps, maxed weight transfer, and stiffened up the front skid shock and have the rear shock (clicker) set to soft.
Do I have my rear shocks backwards? Any other suggestions are appreciated as well.
cycleone88
- Mar 23, 2014
first thing, you have to shorten the front limiter straps if you want more ski pressure.
TRiGGeR605
I'm aiming for less ski pressure. I want the front end to pop up easy.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
If that's the case, I would think you would want the centre shock pretty stiff. MS
NS FX NYTRO
Centre shock stiff with limiter straps all the way out will take weight off the skis.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
if you had a shorty before and a xtx now..... your xtx will not transfer the same as you shorty would
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
Lack of ski pressure is not an issue on the XTX. If you do any amount of trail rideing you will be looking for a solution to the excessive ski pressure and hard steering.
