chain case adjusting bolt loose from new!!
yamamarc
Massey Ontario
Canada
2019 zr9000 Ltd
hey guys I'm in the middle of doing some maintenance on wife's and my sled for our big trip. I pulled the muffler to check the chain case adjustment and found the lock nut and bolt loose The bolt was loose about 2 full turns! Should I pull the chain case cover and inspect or you think it ok!! I had no issues while running
It should be fine. It uses a spring loaded tensioner, just tighten it up and make sure there is fluid in it.
ok thanks!! I hate when thing aren't where they are suppose to be
1 1/2 turns out after finger tight...whatever you do don't get it too tight.
