hartattack
Can someone please explain to me how a apex manual reverse chain case works? I put mine back together the way it came apart and it does ot seen to operate properly. I am not understanding how the reverse works.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
How dose it not work right. Did you follow this for help you may of put some wesher backwords
http://www.yamaha-motor.com/sport/parts/home.aspx
NY AttakGT
Did you make sure to slip the forks (attactached to the linkage on the chains case cover) inside the grooves on the bottom gear assembly? It is a bit tricky to do..as you have to look inside down inside the case and manipulate linkage as you are putting the cover on.
--Steve (O.C.)
--Steve (O.C.)
YAttak07
x2
my bet it is the slip forks. Look in the FAQ section under how to change gears. There is a really good picture of what you need to do. Helps to disconnect the linkage so you have a greater range of movement (up) while sliding the case back on.
Budweiser
Been there, effed it up!! Check the forks. They are always a b&tch for me to get right. Bloody knuckles, swearing, some punches will usually get them in....or let it sit for couple hours, try again and sometimes goes right together. Weird how that works!!
- 8K
