Chaincase casted into the die-cast frame?
PowerValve-700
Labrador City, Canada
Website
www.totallyamaha.com
Tough enough to handle a chain failure? Could get expensive! :o|
Probably wouldn't have any problems with 80HP but what about say 110 force fed HP? And now the warrenty is void.
Thoughts and opinions?
i think its highly unlikely. it would just blow the cover to pieces. way to solid to damage the integrated section
Yeah I'm sure it was considered during the engineering stage. I'm just getting over excited now, I can't wait to see the new Phazer in real life and go over it with a fine tooth comb to see what it's made of.
Shouldn't be much longer and my dealer will have a couple of demos.
The rep said that the cover is designed to go basically wrap around the chain and is recessed into the frame a little bit so the cover will take the hit if a chain breaks. I think it is the same chain as the Apex so there should be no problem with 80hp
