Chaincase Dipstick Tip BROKE
mapo
Ontario
Canada
Apex Gt
So as I was waiting for the engine oil to drain on my 04 rz warrior I pulled the chaincase dipstick, I guess I pulled it at a weird angle and it came out a bit bent and a peice from the tip was missing, I herd it break off.
Should I be worried at all or if I drain the oil will it come out , and/or is the plug magnetic, I don't know how to take the cover off the chaincase to really see where the peice is, or should I leave alone, never had this happen so not sure what to do.
pull the cover and get the peice out. odds are it is too big to go out the drain hole.
this is on how to replace the track on that sled but all the info for pulling the chaincase cover off for inspection is there.
