Chaincase oil viscosity?
vmaxcrazy
Swartz Creek, Mi
I know I've read it here before, but I can't find the post on chaincase oil vis. :o| I know there are different options, But I'm concerned because of some of the chain case problems others have had. I mostly just run my 06 Attak fast in short spurts. (I've seen 121 on speedo on one occation). I'm planning to put a woopping :die on a buddy of mine who has a Apex and may need to hammer it for a long pull to take him. :flag: Again my question: What is the best oil and what viscosity.
Any oil, synthetic or not, should be fine. An advantage of synthetic though, is better low temperature flow. For short bursts, a fairly light oil would offer the least resistance - I've heard of some people using ATF without problems, but I would limit use of this to drag sleds. For long distance (=high temperatures), you really want a fairly heavy oil though (say 80+ with no ceiling regarding how heavy).
Hi, I like to run Mobil 1 in the 75w90 type. Has worked well over the years and is priced right at about $8.00 for a quart! That is a few changes between purchases. Changing it regularly, at least once during the season and again at the end is part of my maintainance program. :yam: Good luck to you and regards, Chuck aka michmobiler
