Chaincase Oil
Daranello
Suspended
Sudbury, Ontario
Is this stuff anygood???
Maxima Snowmobile Chain Case Lubricant is a 100% synthetic formulation specifically designed for low temperature flow while providing outstanding lubrication to highly loaded chains & sprockets with minimum power loss. Also contains special rust & corrosion inhibitors.
Technical Data
Color D 1500 Green
Gravity °A.P.I. 25.1
Viscosity SUS @ 100°F 760
Viscosity SUS @ 210°F 126
Viscosity cSt @ 40°C 163.0
Viscosity cSt @ 100°C 26.5
Pour Point, °F -40
Flash Point, °F 420
Fire Point, °F 455
Viscosity Index 199
SAE Viscosity 75w140
the key here IMO is 100% synthetic....dont think brands matter as much as type.
I use REDLINE shockproof lightweight chain lube...like it alot.
Dan
Daranello same stuff I get from my Yami dealer. I've been using it for years. Put it in before I rode the sled and have had no problems with it. Will check the weight next time I go in the garage.
I have been using Mobile 1 Synthetic 75W90 gear oil. I can pick it up at any of the brand name auto parts stores here in town. I think this stuff is 100% synthetic. So is there anything on the market that is proven to be more effective and thats is also priced about the same or a little more??
Daranello said:
So I guess its safe to run then??? Wonder if the chain will run cooler with the higher weight
Unless the chaincase is running at an obscene temperature, you're wasting your money on 75W140. No, it won't hurt to run the 75W140 but you won't gain anything either. The 140 was developed for running in more late model differentials that don't get the cooling they use to see and therefore their temperatures sky-rocketed. And it won't run cooler using 75W140.
