Chaincase torx screws
MDGFLHR
Windsor Maine
2011 Apex SE
Anyone else have issues with getting the one torx thats by the footwell frame member out? Heat? It actually started out fine but emded up stripping and slowly using vise grips to get it out. Any recommended replacement bolts? Thanks what a pain in the #*$&@ and stupid design if I must say
Several people have replaced with hex head with success. Much easier to remove next time. Search should provide specs on the replacement.
Be sure to run a tap through the holes to clean all the old Loctite out. The new bolt will thread in much smoother and help avoid over torqueing and stripping.
MS
Swivel head extension, it will come right out.
I used a swivel head feels like alot of threadlocker was used last time it was serviced and once it slipped once it was about worthless
