Daranello
Suspended
Can someone tell me how much chaincase oil the nytro takes...I'm at the store buying some series 2000 Amsoil and its only 12oz or 355ml
Manual says to use dip stick but mine took less then 12oz you should be good with one bottle
Daranello
Suspended
Daranello
Suspended
i bought this
Series 2000 Synthetic Chaincase Lubricant (TCC)
AMSOIL Series 2000 Chaincase Oil provides superior protection and performance for enclosed chains. Ideal for snowmobiles, ATVs and general equipment. Extreme pressure additives provide extra wear protection. Extends chain life repels water, and inhibits rust, oxidation and foam. Superior low temperature starting, performance and protection.
X2 12oz is plenty. . . .
yamahaboy701
There is a yamaha tech bulletin about using 200ml not 250ml on the nytros. So less than 8oz for sure.
NLVMAX
- Jan 18, 2008
250ml which is 8oz is fine.
Nitrousman1
It won't take a full 12 oz bottle, I just did mine and 8oz sounds about right with reverse.
IA Rider
- Oct 12, 2009
- Floyd County, IA
- 2017 Ski Doo Enduro 1200
It only holds around 6.2 us oz? Remember its easier to add more than to take it back out.
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
Where do you fill to on the dipstick??
