change Ski Stance
Jona$
Master
Northern
Sweden
Tapex/sks 800 -16
I have a Apex gt thats been more turned into a mountain but have still the standard front end its to wide, cant throw it the way i want or tip it quit easily.
org ski stance is 42.7 / 1084.6 fixed
Mountain ski stance set in minium 37.6 / 955
that gives me 5.1 " more narrow front end?
would that be enough and what do i need for a convert?
Should i be better of just cutting what i have on.
Im sure there are plenty of guys out there thats done this.
http://www.snowmobile.com/specs/yamaha/ ... ex/gt.html
http://www.snowmobile.com/specs/yamaha/ ... ntain.html
also saw the mountain could switch ski stance between 2" how is that done?
i also just found a 09 mountain, should i be cool with a-arms,stabilizer arm,tie rod and then use the rest i allready have on and my Gyt shocks?
The best way to get what you want is to find MTX front end and swap your front out.
but what excact can i hold on to and what need to be replaced.
A-Arms and tie rods, everything should be the same. Check the shock length between the GT and MTX.
