Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
I have a Apex gt thats been more turned into a mountain but have still the standard front end its to wide, cant throw it the way i want or tip it quit easily.
org ski stance is 42.7 / 1084.6 fixed
Mountain ski stance set in minium 37.6 / 955
that gives me 5.1 " more narrow front end?
would that be enough and what do i need for a convert?
Should i be better of just cutting what i have on.
Im sure there are plenty of guys out there thats done this.
http://www.snowmobile.com/specs/yamaha/ ... ex/gt.html
http://www.snowmobile.com/specs/yamaha/ ... ntain.html
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
also saw the mountain could switch ski stance between 2" how is that done?
i also just found a 09 mountain, should i be cool with a-arms,stabilizer arm,tie rod and then use the rest i allready have on and my Gyt shocks?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
vmax4ever said:also saw the mountain could switch ski stance between 2" how is that done?
The best way to get what you want is to find MTX front end and swap your front out.
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
but what excact can i hold on to and what need to be replaced.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
vmax4ever said:but what excact can i hold on to and what need to be replaced.
A-Arms and tie rods, everything should be the same. Check the shock length between the GT and MTX.
