rfrase
- Jan 28, 2013
Hello.I changed the plugs on my 2007 phazer and now the low fuel and gas light are flashing.any ideas? Thanks much
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
Did you get the sender on the tank plunged back in? I think it's on the top right corner.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
X2
rfrase
- Jan 28, 2013
Did you get the sender on the tank plunged back in? I think it's on the top.
rfrase
- Jan 28, 2013
Is that under the plastic that goes on the top of the tank?
rfrase
- Jan 28, 2013
I did make sure the one on top of the tank was plugged in under the seat
- Nov 1, 2009
- 2009 Phazer RTX
Yup, right by your right knee if you're sitting on the sled on the front side of the tank
rfrase
- Jan 28, 2013
Thanks much will check laterYup, right by your right knee if you're sitting on the sled on the front side of the tank
- Nov 1, 2009
- 2009 Phazer RTX
Just to make sure, I've been there before. Have a look in the tank to make sure it's not just low on fuel. It flashes differently when the sensor is unplugged vs. Low fuel but it's a simple thing to check.
rfrase
- Jan 28, 2013
Yup.I put 4 gallons of premium in it right away.thanksJust to make sure, I've been there before. Have a look in the tank to make sure it's not just low on fuel. It flashes differently when the sensor is unplugged vs. Low fuel but it's a simple thing to check.
rfrase
- Jan 28, 2013
Thanks so much for the help.it was indeed a missed plug.I will have to bring out the beer when we're done next time.on a side note I like the sled but what a b:::h to work on.don't get me started on the oil change
- Nov 1, 2009
- 2009 Phazer RTX
Then my bet is that the fuel level sender is not plugged in
- Nov 1, 2009
- 2009 Phazer RTX
Ah you replied while I was typing. Glad it was an easy fix. Some aspects of the sled are not easy to work on but I much rather work on the phaser then the sleds that you can't remove the body panels. May take longer to get to some thing but once I get to them it's easy access, almost everything is nice and open lol.
Missing a plug is no reason to put a hold on the beer lol.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Thanks so much for the help.it was indeed a missed plug.I will have to bring out the beer when we're done next time.on a side note I like the sled but what a b:::h to work on.don't get me started on the oil change![]()
Glad you solved it. It get easier to work on the more times you do it.
It does get easier. Heck my Viper took 5 hrs to remove front subframe after ripping a-arm off! Phazer I could have had it off AND repaired in about a hr.
