great white north
- Jan 21, 2006
- 2011 apex se
Is it possible to change Hyfax on an 06 apex gt without rear skid removal.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
yes
DYNAREX
yep just did mine
Genesis Extreme
You may need to "notch" out 2 of the windows in the track.....staggerd of course.........then get the slides pulled out a few (4"-6") inches.......put the machine in reverse and hit the gas! Pulls them right out for you! I do mine 1 slide at a time, when putting the sled in reverse and hitting the gas.
Then put your new ones on.........after you find the windows in the track you notched out!!
Good Luck!
Good Luck!
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
Yes, they do squeeze through the windows, make sure to clean up your rails before installing the new set, a lite coating of lube helps to slide them on also
great white north
- Jan 21, 2006
- 2011 apex se
Thanks for the great info guys.
DYNAREX
no need to cut windows-spray some silicone or grease on the inside and outside of window and shell slide right through-do not use a wd40 type lube though-silicone grease is best
also drill a bunch of tiny holes down the slides for better resistance to melting them
Bodacious
We used to this on our drag sleds, but found that for trail use a lot a grit gets inside of those divits and caused pre-mature track clip wear.DYNAREX said:no need to cut windows-spray some silicone or grease on the inside and outside of window and shell slide right through-do not use a wd40 type lube though-silicone grease is best
DYNAREX
angle the holes to the rear and the debris flows out of them
