If Ohlins shock, disconnect wire connection behind reverse lever beside chain case feed wire back through tunnel as I don't think the wire is a quick connect on the shock itself.
Likely the shock wire is bound to swing arm with tape or similar protection which will need to be removed.
Like steiner said, take the pre-load off the suspension and remove the transfer rod at one end, easy peasy from there.
