turkster
- Feb 1, 2008
- opaskwayak manitoba
- 2014 nytro xtx
Its getting minus 40 Celsius here. Need to know if anyone has circulating heater installed on their bike. If so where's best place for a mounting job. And is there any pics. 450 kodiak
never really needed one but I do run an aircool. most times you just need to pour hot water over the carb to get it to run.
you could use a stick on oil pan heater on the bottom of the engine to warm the oil up. that would work as well.
you would have to put a coolant heater in the return line from the radiator.
