wileya
- Nov 30, 2009
- Forest, Ontario
- 15 sr viper rtx se
just wondering what everyone is using to clean the foam filter in the airbox? mine has some oil on it . have done some searches and haven't found anything.
Metallicat
I use Simple Green and hot water.
steve barber
our trails are so dustly now need snow
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Hot water and soap.
SRXSRULE
I use a garbage can to clean mine. Step 1, Remove filter. Step 2, Throw in garbage can.
Thats it! 2 easy steps and its a one time service
Eric
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
soap and water i also oil mine before i put it back in it catches belt threads better that way
APEX 06
- Apr 30, 2009
- Sheboygan, WI
SRXSRULE said:I use a garbage can to clean mine. Step 1, Remove filter. Step 2, Throw in garbage can.
Thats it! 2 easy steps and its a one time serviceEric
Lmao
Super Sled
- Feb 25, 2009
- Summit X
Then spend $25 on a new one? They are re-useable for free fyi. Just cleanse a little bit in soapy watere, rinse, air dry, and viola!
smalltownpower
oil vapor oils the filter in a few miles anyway haha
SRXSRULE
If I wasnt clear, I was trying to say I dont run that filter at all. If you ride powder that thing will ice up bad. The screen is the only thing I have ran since my 04 warrior. Thats about 12,000 miles on the rx-1/apex engine combo.
The better option is to remove the air box and install an intercooler in its place
Eric
9kNytro08
- Dec 28, 2025
- Jefferson NY
- 17 sidewinder, 08 nytro, 07 phaser, 06 attak
If im not mistaken I believe thats how the nytros are set up, no foam just screenIf I wasnt clear, I was trying to say I dont run that filter at all. If you ride powder that thing will ice up bad. The screen is the only thing I have ran since my 04 warrior. Thats about 12,000 miles on the rx-1/apex engine combo.
The better option is to remove the air box and install an intercooler in its placeEric
