If you want or are willing to start from scratch I would say do this but that's just me. First, raise the front of the sled untill the skis are off the ground. loosen both shock coils until the springs just start to rattle. Then slowly tighten until the rattle stops, from here tighten one to two turns. For the clickers, the compression, set at the softest/fastest setting on both shocks. On the rebound side, set at the fastest/least dampening effect. On the next ride adjust as required, ie: if the front seems to bottom increase the compression dampening maybe two clicks at a time. If the front seems to bounce back or kick back increase rebound one or two clicks at a time. Whenever possible try to ride the same section of trail when adjusting as it will make it easier to understand what the effects were. If you find that the front bottoms even with the comp turned way up tighten the coils a few turns. The reason for the low preload on the front is to lower the front and improve cornering, reducing inside ski lift as well.
