Clicker
capewarrior
Cape Cod Mass.
Does the clicker on a 2004 warrior change my FRA? I noticed that the rear shock still has settings for the spring. So what does the clicker do to the shock to make the ride softer or more stiffer. Sorry to be asking such stupid question I just want to know everything I can about my rear suspension. thanks
Shock resists motion. Spring pushes back. Adjust the spring to have the right sag-in (halfway on the transfer rods), then adjust the shock to limit stroke on big bumps. Then try changing the FRA to another setting and try everything again until you find the best position. Note that changing FRA will screw with both shock stroke depth AND spring rate.
