gun nut
Has anyone solved the clock problem where the clock goes to 1:00 when you turn on ignition?
Did you check for constant power at the circuit going to the clock????
gun nut
clock
I'll check that-thanks
bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
I have the same problem but have been too lazy to dig into it. If you get it sorted out, I would be curious to hear what was causing the problem for you.
Fergie
- New Jersey-Ride Old Forge N.Y.
check your fuses
