THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
The hose that doowithblue is referring to has been eliminated on the 22 XTX wastegate solenoid has just the hose barb on it pretty sure mine froze up with moisture producing low boost situation. I added a 6” hose hanging down that should stop that from happening again. That hose used be routed to air box.
Pretty simple mod
Pretty simple mod
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Thank you for the info very interesting
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
No issues without the hose on my 22.. This was something I learned when I went to install a CAI and it had a nipple for the very hose you are referring to.The hose that doowithblue is referring to has been eliminated on the 22
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
The issue arose when I was in -15*C temps running off trail in very sugary type snow had lots of snow dust under hood and on air filter sock. It was doowithblue issue with oil in that hose that got looking into that hose. I figured the short hose hanging down was a good solution to having it happen again
Thank blue for your help
