quebec#1
I have a clunking noise on my primary clutch if i give it gas just about when it will engage and then let off it will clunk . Can it be a broken spring ? The machine still takes off well and hits about 10500 on the rpm guage.
grader
sounds normal to me. the noise is the spring opening the clutch when the rpm drops, just as you described.
SKIP
quebec#1 said:I have a clunking noise on my primary clutch if i give it gas just about when it will engage and then let off it will clunk . Can it be a broken spring ? The machine still takes off well and hits about 10500 on the rpm guage.
Are you sure it's not the play in the secondary you are hearing?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
check your chain tension...possibly too much slack
quebec#1
Nope its the primary its like the noise you hear if you run the clutches without the belt on.SKIP said:quebec#1 said:I have a clunking noise on my primary clutch if i give it gas just about when it will engage and then let off it will clunk . Can it be a broken spring ? The machine still takes off well and hits about 10500 on the rpm guage.
SKIP
quebec#1 said:Nope its the primary its like the noise you hear if you run the clutches without the belt on.SKIP said:quebec#1 said:I have a clunking noise on my primary clutch if i give it gas just about when it will engage and then let off it will clunk . Can it be a broken spring ? The machine still takes off well and hits about 10500 on the rpm guage.
Hmm, I have never heard a clunk in mine, and have 5500 miles on it.....sounds like it's sticking. Maybe it's time to ask a professional (Russ), he will probably tell you to take it apart and check weights, check the bushing and replace the spring.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Definitely look inside the primary, take it apart and see. Could be a broken spring, maybe worn bushings or weights. You don't want to let that continue and cause damage, or worse, injury.
When is the last time you serviced/cleaned the clutches?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Maybe even the clutch bolt is loose or broken.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Im believing the sticking idea...Ive taken some apart that would barely close from belt pitch built up in the towers...after cleaning smooth as silk!
quebec#1
I didnt have time to get a good look but if i engage in a smooth matter its ok even on the trails but from a full stop and giving it gas just as it engages when i let of the gas it will clunk.sj said:Im believing the sticking idea...Ive taken some apart that would barely close from belt pitch built up in the towers...after cleaning smooth as silk!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
that it snapping back to full open from a partial engagment and it sounds like you have a little "stickion" going on there like I said..
