Sno Cat
I'm also thinking track is ratcheting. Check tracktension. If running stude, tighten track to the low end of the spec, if no studs the track can be tightened to the high end of the spec. The tension gags sold by Woody's is invaluable.
Check the transfer rod jam nut, make sure it's not loose.
Check all other suspesion bolts make sure they're tight.
The sleds are bulletproof, it's probably something minor.
