Clutch alignment tool
That is by far the BEST clutch tool you can buy. I love mine, makes alingment a one man job and it dont take 10 trys to get it right. ===SRXSRULE===
I own a 05 Vector and an 01 Phazer Deluxe - Are the clutch tools the same for these two sleds?
1. Puller
2. Compressor for secondary
3. Primary Clutch Tools for disassembly
4. Clutch alighnment
I believe the are the same.
Hey BBY, what is the purpose of that clutch service tool in the first picture and how is it used? I have one similar to that, but not sure how to use it.
The sled pro tool does both center to center and offset at the same time.
hlmrx1
That tool allows you to change weights and rollers without removing the clutch or cover. The forks fits into the spider and you use the leverage to compress the primary spring, then use the second piece across the sheaves to hold the clutch open. I have this tool and it works well for tuning.
The clutch breakdown tool is used to break down your primary. It removes the spider from the fixed sheave. You simply take the clutch face off along with spring, set clutch into flat plate with the 3 pegs in back of the fixed sheave and turn clockwise to loosen. Its threaded like gas fittings. It may take some heat to get it loosened up, it is very very tight. You will need to use a long breaker bar that insterts into the round piece you put over the top of the spider.
As noted before the service tool is used to change weights without taking the clutch face off and lets you do it on the sled...BBY
sorry yooper, wrong. center to center can also be adjusted, and is often overlooked because people believe the motor is solidly mounted.just loosen the 3 bolts that hold the motor, and you can move it a lot.
alinment
aliment is a must these moters move a lot. i have found more than a few out of aliment c to c and off set and out of paralel
