B440
Hey, Only have 69kms on my new Nytro RTX and I am wondering what does everyoner elses clutch engage at? I noticed on my first ride that sometimes it will engage around 3800-3900 and a few times the sled wouldn't move till about 4800. You could aslo smell the belt burning a bit. What is going on? What do I have to adjust?
Kråkan
You should look at the settings on the clutches.. Maybe the driven clutch is set alittle to soft? Or did you get water on the clutch?
NyTrOMaNIaC
I find engagement is at around 3800 rpms most of the time, depends on how you throttle it up. It seems like the digital guage isn't quick enough to register the rpms at engagement if you hit it fast, but if you feather the throttle, you'll get a more accurate reading.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Engagement will be in the 3800 rpm area stock. Remember different ground conditions will affect the engine rpm at which the sled will actually move (skis stuck into ground, etc).
