09nytro
Is anybody using the Schmidt brothers clutch guard /wet foot....if so hows it working is your foot getting wet
jb_008
- May 21, 2012
- Sault Ste. Marie, On
- Yamaha Nytro RTX SE 09
Never had the wet foot problem myself, but I bought it more because the stock guard crumpled like an accordion when my belt blew last year. I figured it was cheaper protection than having to replace the plastics if it happened again.
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
Buy it for the protection. I had the wet foot problem and it is much better with the plate installed. Not tottaly solved but much better...
09nytro
Cool...well long story short...my buddy put a tree branch through his oil tank and I pulled him home.....didn't change the belt (to lazy) and well
and that plate is bent the f...up....lol....
never had the wet foot problem myself but looks nice in pics ...well it messed up the foot well too does it keep that protected too....
and that plate is bent the f...up....lol....never had the wet foot problem myself but looks nice in pics ...well it messed up the foot well too does it keep that protected too....
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Have you closed out the hole going from your tunnel by the drivers into the clutch area with a bolt yet? That was my biggest cause of my wet foot. That and close off the toe hole vents. I'm pretty good now without any plates installed. Without that bolt in,water use to pour out of the toe hold down area catch the wind, instant wet leg/wet foot
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
where exactly is this, gives me something else to do waiting for the end of feb.... although it looks like i might be able to ride crappy trails around the house in the coming dayssorenson1610 said:Have you closed out the hole going from your tunnel by the drivers into the clutch area with a bolt yet? That was my biggest cause of my wet foot. That and close off the toe hole vents. I'm pretty good now without any plates installed. Without that bolt in,water use to pour out of the toe hold down area catch the wind, instant wet leg/wet foot
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I didn't see it till this summer myself. Look in the nytro faqs, left wet foot. They must have added to it in that post. Its a bolt hole in the cast frame that will let snow/water directly into the clutchs. Its under the primary right on the line of the bottom plastic trim piece. Bolt with neoprene washers, fixed 90% of my wet foot.
Dodge Ram
SB protector
It works great. I had to replace the OEM one as it was trashed after the belt blew south of wolverine area. Thicker meta,l so I would think it will work if the belt blows again.
09nytro
Right on ...I got one coming should be here tomorrow Chris said......
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
I made my own belt guard. Close to the SB one. Plugged the hole under the clutches and it doesn't solve the wet foot problem. What causes the wet foot problem is all the heat coming out of the side panels hitting your leg and then the snow hitting your warm leg and boot . It melts and causes your wet problem. On the trail I have no wet foot, playing in powder foot is wet. What I tried last weekend was spraying my boots and pants with water repellent and it helps a lot. Probably have to spray them every once in a while. I will do this until I can swing another $1000 for a Klim suit and boots.
