dirkdiggler
Suspended
OK boys I've spent 2 weekends testing clutching Here are my results. First off I have a 2006 Attack. I installed a 136*15*.5 speed track with 200 plus 1.20 t nut style chisels "she hooks like a monster". I have a friend that has a very good running 99 snopro with a 890 psi motor. It makes about 180 HP and is very light "475 Pounds". In 660 he runs 5.9's. his sled is the sled I used as the gage of how each package worked. Here is a list of each package and how they performed against his sled. all the results were on glare Ice on measured 660 tracks.
1. Stock clutching.
With the stock stuff he beat me 8 to 9 lengths depending on the take off.
2. Ulmer racing.
I started out with the trail package and he was beating me by about 5 plus lengths in 660 and pulling hard beond that mark. After a couple runs I checked the clutches. The Secondary was very hot. I decided to switch to a green secondary spring from a silver and I wrapped it a 60 degrees. This was a huge improvement but with the great traction I need a higher engagement. I switched to a Maxx White which has a high preload and bumped the engagement and this helped make it jump out of the hole better. Buy the end of the day I was about 2 sleds behind him and if we continued to lets say 800 plus feet he's be back to the 5 sled lead. I feel there is some potential with this package to Improve with a gearing change an increase in Primary weight mass to load the motor harder with the lower gear ratio. Final full shift RPM's where about 10500 to 10700.
3. Proline
Bolted in the kit and went to work on the track. When we started he was an honest 3 to 4 lengths ahead of me depending on my hole shot. The Proline has a different engagement the The ulmer. It slams in unlike the Ulmer that Rolls in nice an smooth. So it took some time for me to master the take offs. After a couple passes I checked the Primary and secondary for heat. They were both hot but the secondary was much hotter. The Secondary spring Proline uses doesn't have the tines offset 180 like most Yamaha springs. So Setting preload is different. I set it as soft as I could get it made a solo pass and it seemed stronger by feel. I checked the clutches for heat and the secondary was luke warm. The Primary was still hot which I think is a result of a the extra traction combined with stock gearing being a tad Tall. This setup could also use a gear change and a load up on the primary weights. When I got the sled back together we took them out and In 660 he was 1 sled quicker and 3 in 800 plus. Full Shift RPM was 10500. Proline suggest 11000 but It didn't run good with the secondary twisted up. When I had it tighter it ran 11000 but the big end fell off.
I raced a lot of other sleds including some apex rtx's and one Super charged GT. I handed it to the RTX's and beat the SC to the cones. In fairness to the SC he was running trail studs and was spinning like mad at the start. and He went by my a the cones like a freight trail. I raced several F7's. The only ones that beat me used NOS. I also beat up on sever ZR900's which I had huge trouble beating with my RX-1. most of the time I was on the losing end of those races but not today. It was so great beating up on the Kitty cats. They get so pissed.
Conclusion
I've read several posts about the Proline kit being 5 to 10 sled quicker then the Ulmer setup. That's just Flat out untrue. Under this testing" which was controlled" it was no better then 2 sleds and that was in 800 feet. The Funnier part of that was setup as they come from the companys they ran within a sled lenght of each other with the Ulmer setup having better trail manners. Both the Ulmer and Proline would benefit from gearing changes and Primary weight increases. That combined with the changes I already made I might squeeze a sled or 2 out off the Proline. I think I could get even more out of the Ulmer becuase of the way you can load the Super Tip weights they use. The other Nice thing about the Ulmer setup Is the weights can be changed on the lake as well. The Dalton weights in the Proline setup require some Major work to change them which unless you have a nive heated race trailer your not going to want to be drilling rivits out on the lake.
If I was a trail rider and I had good traction I'd use the Ulmer setup. It's very quick out of the whole and it has excellent back-sift corner to corner as I've found this year on the trail. If I was a racer that wasn't a tuner I'd put the Proline in and some chisels and have at it. If I was a Racer that loved to tune I'd get the Ulmer some gears and a Friend to test against and go out to the lake and make it run!!! If you are a trail rider that isn't looking to add traction stick with the stock setup. It's not aggressive out of the hole or on a roll and work's very well in all conditions.
1. Stock clutching.
2. Ulmer racing.
3. Proline
Conclusion
MOTOWN SPEEDFREEK
that sounds good dirk, Ill take the Ulmer as soon as my wife gets back to work!!!
dirkdiggler
Suspended
Your going to havee to talk to Allen. I'm keeping my sled now and I'm keeping the Ulmer setup as well. I think it was he potencial to be the quickest kit on the Market with the right Gearing and weight setup!!!
vice108
Thanks for sharing Dirk.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Good report Dirk.... I bolted in my Proline today and my buddy on his very well tuned F7 used to be me by 3 sled lengths on the high end and today I walked by him on top end and just kept on pulling. Both sleds had the same amount of studs. He had 102 and I had 96. We ran test after test in 1 miles run on a hardpacked groomed trail (open field but the groomer runs through it. Dream Meter was 126, which was 3 mph faster than I ever had it going. I also did a gear change of one top tooth lower. You are correct, though this kit loves traction and I it believe will dominate over some of the competitor kits. My sled was running 10,900, with the seondary rapped at 90 degrees. I'm going to keep it just for the drags and may put the stock stuff back in with some various changes of the clutch it self with some of the components. When I'm all said and done I will report my findings.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Well i have not tested any thing other than ulmer kit i made up,with stock helix,as i have used hh and hc in my 03 rx1 and had my best resultd with hh in the rx1,but so far stock clutching works good for top end,but what allens kit does for my now short track and my 23 top attak gear,is just soo sweet i may just leave it along,oh maybe not,i still need to know if the 24 stock apex gear will pull better top end speed on bare ice than this 23 does,and i will not find out until next winter aaarrr shoot...
mclarenyamaha
what about simmons cpr, i have one and is very happy about it, but i have not done any real testing. but ai am very happy with trottel respons and backshift. does anbody of you tested it aginst proline and ulmer kit, now we are talking unstudded.
RTX Meirda
I tested the proline kit this weekend. Works! Gave me 2 MPH in 2000ft and got there quicker too!
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Good report Dirk...on Sunday MachZed Dan and I found that his Proline kit made no difference in 2000 feet on the radar gun vs stock components.
The difference WAS, he was revving 11000rpm and I was revving 10500. He was consistantly 2.5-3.5mph faster. Didn't matter if I rolled on the gas for 700 feet, my top speed was the same +/-1mph, same with Dan.
And I have always known the 'Kits' to be quicker for short distances as you have proven!! However, TRACTION is key if you are gonna use a 'KIT'....as a stocker with adequate traction is gonna give you a run for the money!!
dirkdiggler
Suspended
It looks like the Phatman Challenge is in 2 weeks. I'm going to make a gear change and some tweeks to the Clutching and I'll update this post to let you know if either kit imporved.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Did you try the gear change yet? Try the 23 and if you like that then change to the 40 bottom. It works even better.RTX Meirda said:I tested the proline kit this weekend. Works! Gave me 2 MPH in 2000ft and got there quicker too!
RTX Meirda
SledFreak said:Did you try the gear change yet? Try the 23 and if you like that then change to the 40 bottom. It works even better.RTX Meirda said:I tested the proline kit this weekend. Works! Gave me 2 MPH in 2000ft and got there quicker too!
No....I have the 23 top gear but have not installed it.
I want to get as much as I can out of the sled before I change it....then I will know if it is better or worse.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
freak,
are you saying to use 23/40?..together?...or that 40 with 24 is better then 23 with 38?
thanks
dan
SledFreak
- Feb 7, 2005
- Ontario. Canada
Use the 24 with the 40 bttom. You will gain top end... I have not tested it, but from the several people that have tried, have all said it works great and helps alot in the mid pull to top end and will give more top end. I personally have gained with just the 23/38 gear combo in the mid and 4 mph on top end on hard pack, but I have been told the 24/40 is better all around and will give more top end. Three different Apex tuners have told me the same thing and all have tested Proline, Simons and Ulmers and some have made their own. Even without any clutch work, they all said the gear change works.
machj
im looking for a 40 tooth for my gt with reverse anybody know which dealers in canada have them
