clutch puller?? do i need one?
I dont have a Yamaha puller. I do have serveral 2 and 3 jaw pullers and such.
How can I pull my Rx1 clutch?
:exc:
:exc:
srxguy
I would get one and add it to yout tool box
- Sauk Prairie, WI
- www.ty4stroke.com
If you have to physicaly get the clutch off the sled, then yes you need one. However, you can take off the clutch cover by loosening the 6 - 10mm bolts on the clutch cover. Once cover is off, you can change weights and rollers while the clutch is still on the sled. So, it depends on what it is you are trying to accomplish.
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
This is something that needs to be done to disassemble the engine. If you can't borrow one from someone make sure to buy a good quality puller so you don't cause any other problems. It needs to be a clutch puller not a three jaw puller,Ken.
givemeaboost said:This is something that needs to be done to disassemble the engine. If you can't borrow one from someone make sure to buy a good quality puller so you don't cause any other problems. It needs to be a clutch puller not a three jaw puller,Ken.
Yeah, I thought so. I think one of my Yamaha buddies might have one, if not I'll go shopping...
- 10K
