1975FA
I was looking at clutch pullers on ebay. They list a puller for the 06 to 09 Nytro's. What changed after 09 with clutches and or cranks to need a diffrent puller? I have an 08 RTX so this puller should be fine. I was just wondering if there is any changes?
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
No
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Be careful with some of the pullers on e-Bay. Some are crap, I broke one as well as a buddy of mine. Spend the $40.00 for a good one that will not break and save yourself a lot of headaches. We broke the end piece inside the clutch and went through hell to get it out!
1975FA
Apex2006 said:Be careful with some of the pullers on e-Bay. Some are crap, I broke one as well as a buddy of mine. Spend the $40.00 for a good one that will not break and save yourself a lot of headaches. We broke the end piece inside the clutch and went through hell to get it out!
Just curious, were you drawing it down with a hand wrench when it broke or did you hit it with an impact?
grumpysanta
ALWAYS USE ANTI SEIZE EVERY TIME YOU USE IT .
nytrolabrador
JUST BUY A GOOD ONE AT A LOCAL SHOP..
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
The clutch puller I have for my old '99 SX 600 looks identical to the Nytro clutch puller OSP advertises on ebay. Will my old one work on my '08 Nytro.
Also, I always pump grease into the cavity the puller fits into to create hydraulic pressure along with the mechnical force the puller creates. It take A LOT less torque on the puller to get the clutch off using grease (water works to if you tip your sled on its side) then just the puller itself.
grumpysanta
I am using a old clutch puller from my srx for my nytro xtx 1013
09nytro
Yes it will work ...I'm using the same one on my 97 xtc 500 , 02 viper ,09 nytro , 07 apex ,08 apex.......puller hasn't changed in a long time......
grumpysanta
clutch has not changed or the belts
