ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I did a search on this and get a million posts, but still no direct cure...
I have an 04 Mountain and the clutch rattles at idle. Fellow RX riders say it's normal and not to worry about it. Everyone who hears my sled comments on the clutch. It has 2500kms on it and I bought it new to me last spring.
Any quick fixes?? I've read from carb synching to replace clutch parts. Clutching is bone stock.
What you are hearing maybe the gear reduction system on the sleds.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
I turned my idle up a couple of hundred RPM until it went away.
Not so choke fussy on a cold start was the bonus.
A little less engine braking too it seems
BURMAD69
Sync your carbs and turn up your idle a couple hundred, Worked on my RX
03griz
Dealer installed the same update as was done to the vectors. 14 bucks for the kit and half an hour labour. No more noise, only a little reduction noise. No rattle.
JD
- Apr 14, 2003
- Manitoba, Canada
- 2016 Venture TF-LE
03griz said:Dealer installed the same update as was done to the vectors. 14 bucks for the kit and half an hour labour. No more noise, only a little reduction noise. No rattle.
What does the update consist of???? I hate that rattle at low idle too....
03griz
Three o-rings and three new sliders. You have to split the primary clutch so you need the proper clutch tools to take it apart. Make sure you loctite it back together!
JD
- Apr 14, 2003
- Manitoba, Canada
I think we may be talking about something different!!! The rattle I have is from inside the motor housing....The reduction gears as i understand it...
03griz
That rattle stays, but some of that noise on mine was clutch rattle. All gone now.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
I fired up the sled, turned up the idle and there it was...gone! (the rattle that is)
Thanks guys!
Thanks guys!
Riceburner
- Apr 14, 2003
- N.B. Canada eh
No problem.
Gotta love the cheap and easy fixes.
SLEDSTART
same here. Uped the idle and I agree...less engine breaking and better starting. It likes to idle at about 1600 r's
