clutch setup phazer mtx MPI supercharger
msrx700
quebec
Hi
I install mpi supercharger on my phazer mtx
can you help me with clutch setup
I ride at low altitude
thank
engine make lot of over rev (12 400rpm +) and cut
-I try bigger rivet (2x 4.5g) from yamaha in the stock weight 8dn-17605-30 40g (total 49g) and same thing
no good result
-I install Schmidt Bros Motorsports stage2 kit (300$) with helix, front spring, and rivet (total 53g)
no good result
-after I add 1 tooth in chain case gear
no good result
-so I change secondary (yellow) spring position from b1 = 60 degre like said by Schmidt Bros Motorsports
and switch to c1 = 40 degre
no good result
so now the last thing i can do is to buy expensive weight from yamaha ?
if yes which one?
yamaha have listed for phazer in is optional part for primairy clutch
-68g ,3 holes 141$kit (all phazer) 8fp
-65g ,3 holes 203$ kit (all phazer) 8fs
-47g, 2 holes 139$ kit (all phazer) 8gc
-40g, 2 holes 152$ kit (MTX only) 8dn (mine now)
my first choice it's to go with 68gram 8fp-17605-00 ?
give me your advice
thank you
Try Allen Ulmer, he's excellent with clutching and can easilly get you fixed up!
I too would like to see an answer to his question. I seem to have the same issue but in reverse. Let me ask it again anyways.....what weights and spring are best for boosted Phazer?
