kidastra
is there a guide or how to on rebuilding the stock clutch? 2007 attak, I've searched and came up empty
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Here are a few pointers.
Check for grooves in the clutch sheaves. Run your fingers down the sheaves. It should be smooth and consistent. The stock yamaha belts are prone to grooving the sheaves due to their harder compound.
Weights should be smooth on the surface that rides against the rollers. Sometimes they can become "dished" meaning that have a dip somewhere on the contour of the surface.
Rollers should be smooth and free of any pits from rust.
Clean them. Compressed air works great to blow out all the belt dust. Then wash the clutch with soap and water.
All apex clutches have set screws on the weight shafts. the 06-10 have set screws on the roller shafts also. To play it safe...apply a little heat to the clutch at these set screws so they break loose easier. I just use a small propane torch designed for sweating copper pipe fittings. They are a small allen screw and you do not want to strip them!!!
When installing the cover back onto the clutch make sure you align the "x" on the inside of the cover with the "x" on the spider.
Hope this helps.
Hope this helps.
kidastra
thanks, but I'm looking for a complete step by step, hopefully with pictures.
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
I don't think that will exist bud. Really it's not that bad. I'm sure there are lots of guys around that can help.
kidastra
damn, so many tutorials on here, nothing on the clutch is surprising! Ok i'll look up all the terms and try to figure out what hibshman25 posted
