heading for mcbride b.c on wed.just got a complete nytro mtx clutch set up from a buddy-primary spring/weights and secondary spring/helix.should i use this set up or just change rivits according to the clutching chart.only running a 1.75 backcountry and a slip on muffler.everthing else is stock.any input would be great.
The Mtx runs 7 tooth drivers whilr the xtx has 9's and the gearing is also different. You should have the recommended setup with you. Could mean the difference of a good trip to a shitty one just because of a few easy to carry parts.
