saskattakman
i need some clutching advise for my 09 nytro xtx. im heading for 8-10,000 ft. running a 1.75 backcountry looking for what wieghts springs and helix i should be running
		sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
Try Scott at OFT, ben running this setup for 3 yrs and is spot on!
			mjaremko
Suspended
Take both rivits out of the stock weights, this will give you about 9,000 rpm in powder.  Zero $'s spent, worked fantastic for me in West Yellowstone last year, same sled, same track.
mj
			mj
clatla
Isn't West YellowStone 6-8000'? I second the give Scott a call at OFT. It is a long ways to go to not have your sled running at peak performance.
			mjaremko
Suspended
Depends on where you ride in West, my Uncles cabin in Island Park ( 30 miles from West ) sits at 7,800 elev, we can ride up to almost 10k elev from there, most of the riding is 8-9,500.
Just a suggestion,
mj
			Just a suggestion,
mj
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
saskattakman said:i need some clutching advise for my 09 nytro xtx. im heading for 8-10,000 ft. running a 1.75 backcountry looking for what wieghts springs and helix i should be running
I've got a kit so I can't help much with clutching but also consider dropping one or two teeth on top sprocket if you have not already done so.... I'm down 2 teeth to 19/39 and works well.
