99SRX700
I am definately getting heavy hitters for my 05 RX-1 but I have many questions that stretch beyond what I can find when I do a search on the topic.
First let me explain what I am looking for. I want the most power to the ground and I want the sled to go with little throttle. I loved the clutch kit in my 99 SRX. It took very little throttle to go and when you rolled into the throttle the sled would respond instantly. The more you moved the throttle the harder it pulled. I have ridden sleds that hardly respond at all until you nearly open it up...then suddenly it comes alive and the sled starts cranking. I don't like that. I am someone who rolls into the throttle not someone who clamps it to the bar like an on/off switch. Another thing I liked about the bender clutch kit is that you could really keep the RPM's down if you wanted to...give it a little throttle and it would shift way out keeping the revs down. But again...if you rolled into it then the clutches would shift out and it would pull like crazy (as you were rolling into it).
The back shifting on this kit was horrible. Every time I matted it the sled would kind of bog...but that doesn't really matter to me since I don't ride like that anyway. Can I get this type of set up from the heavy hitters? Is a clutch kit with that kind of feel going to get me the maximum power to the track? Any feedback would be appreciated...and any recomendations to setting the heavy hitters up would nice too!
