Clutching questions for a turbo set 800-2000 sea elevation.
Chicago IL
Need help with clutch info. I mostly ride in the UP of Michigan and in northern Wisconsin. Can anyone help me please.
I have a MCXpress APEX.
-thanks
My friend runs an '06 Attak with MCX310 turbo kit.
He runs STM Supertips weights at 60 grams loaded 14-14-2.
On the Apex MCX260 kit 14-7-2 would be close running a Dalton Black/Green primary spring.
In the secondary we have been running Dalton 54/48 and the Yamaha white spring at 60 degrees (settings 3+3) Fine tuning for preferences on clutching caracteristics, conditions and tracktion will have to be done.
Supertip weights
Dalton Green spring in primary
Start with 2 tungsten in the heel of the weight 2 washers mid 1 washer tip. Tune the peak rpm from there.
Use a Yamaha White secondary spring wrapped 70*
Something around a 54-48 helix should work.
