Cobra Track-- Single or 2 ply???
I think mine might be a single ply. It's a stock Cat Turbo take off. It has the Cat quiet ride nubs/bumps where the idler wheels ride. Seems to work good, the only bad thing is it is TIGHT getting the suspension back in. When installed the track adjuster nuts are barely into the nylock. You can pick up the Cat take offs a little cheaper usually and if they used them on the 180hp turbo's they should be OK on the Nytro-unboosted. 2000 miles on mine and no problems.
