Code 11
Hey Zach,
This is the Cylinder identification sensor.
I also attached a troubleshooting guide to test the sensor.
Hope this helps.
Thanks! What page of the service manual is that from?
I'll go out to my dads in a few days to diagnose it.
The reason I ask for opinions is because it came out of no where. When I was working on my sled last week, it was never on then a few days later once I got the starter installed, frame reinstalled and what not, I had this code popping up.
Depending what PDF you have page 276, or section 7-14.
Looking at the manual it would be either
1. A wire got damaged. I would follow the wires as far as you can.
2. Sensor went bad.
3. I would check for good measure Fuses. Or even undo the battery cables a few hrs or even overnight to try to reset the ECU. Who know that may fix it? lol
Hope its an easy fix...
BTW did the starter install go well?
Starter install went good. But when I removed the oil tank drain plug as I loosed it, the tank buckled and the threaded insert popped out. I took it too a shop just down the road to have it welded and they called me today saying it was ready. Unfortunatly I didnt get there on time so I will have to go get the tank on lunch. Cost $25 to get it welded.
I hope it runs!
At least it happened no instead on mid season!
Hope code 11 is an easy fix.
