code 13 intake air pressure
sxr1000
minot ND
I have a code 13 flashing,intake air pressure sensor bad, where is it? I cant find it in the parts diagram.
If I remember correctly it is inside the delta box in front of the front left corner of the air box, in front of the battery, Has a plug going to it and a port coming off of it. It is the barometric pressure censor (atmospheric air pressure). I know I could put my hand on it but it's hard to explain.
The temp censor is in the left side of the air box. I had a YamCharger and the air presure hose from the YamCharger air box hooks to the pre sure censor down in front. Actually the presure censor get's moved with the new YamCharger up behind the air box.
