onlyblue4stroke
sled sat for 2 days in a garage (not heated) went to go start it and this happens hope its just a plug tried ur tech tip with disconecting the pump didnt work.... has anyone else had this code or ths problem..... happy new year thnx
terret725
u do an oil change recently? theres 2 hoses that go on to ur air box sensors. one for each cylinder. if they are pluged, diconected or kinked ull get code 14 or 26 depennding on which one it is. just had the porblem after doin my oil/filter change. fogot to hook them up. u can get to them by taking ur head light off. then are right under it.
yam177
Check you map sensor connectors and or vacuum tubes going to them
