Ekvin
- Mar 29, 2014
Sled fired up and idled fine to warm up then ran great for 4 kms then shut down. Rechecked all fluids and everything was good but noticed the oil tank was very hot to the touch and the cylinder head was hot to touch but oddly the oil itself was not hot just warm. Fired it back up and drove slowly watching for warning lights/codes, flashed 35 and shut down again. Walked back to the truck and loaded up the sled to bring home.
What exactly is the code 35 and it cause? The hot oil tank was concerning, likely caused by what ever the code 35 is?
Thanks for any help, need to get pointed in the right direction to fix the issue.
Cheers,
Kevin
Cheers,
Kevin
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
https://ty4stroke.com/threads/fault-codes-relay-fuse-location-wire-diagram-diagnostics.83992/
Code 35 is for the ignition coil on cyl # 3
Ekvin
- Mar 29, 2014
Ok thanks, anyone happen to know what that means? Is it the coil for cylinder 3 needs replaced?
i would pull and test the coil 1st as it could be a connector or wiring issue for that coil.
