pulled stud went through front exchanger had it tiged testerday track here tomorow filled sled with coolant ran it and bled it with out chain case off and drive axle not installed speed sensor just sitting on bolts ran it to bleed air guess it did not have speedo input how do i clear codes i have manual but find it confusing apreciate any help thanks john
those are the TORS and speed sensor code. if i read the manual correctly they should reset once you drive the sled and it sees the appropriate input for those circuits.
thanks jamesc i read my manual and tried to clear must of done it wrong i unhooked my speed sensor one time to keep milage down and as you say it did reset it self thank you john
