Code 84 flashing!
monster
kawarthas
When I turn the handle bars on my sled the engine revs up. I then see an error code 84 and it flashs. I know this is for the tors sensor, but how do I fix it? Is there an adjustment I can do on the throttle cable?
I have had that on my Apex Mtn after messing with the cables and I had pulled to much out. Pushed it back and everything was okay. I also disconnected the TORS- but I have a tether.
read the other post on here about code 84 flashing. looks like your throttle cable may be too tight, my cable was put over the handlebar pad, i put it underneath and problem solved
