fxnytro1050
The tors system is still acting up on my nytro. I can drive as long as i want but as soon as i stop and try to move again it will act up again. As long as i let the sled idle down and i give a quick shot of gas to get moving the tors doesnt stop me and then the engine light goes off until i stop again. Any sugestions? [/u]
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Get a tether and disconnect the tors. Thats what I did.
Believe me, you dont want that thing acting up while in the steep..
fxnytro1050
Do you think it will eventually fix itself.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
No. Maybe it will work for a limited time, and then start acting up again.
Have you adjusted the throttle cable to the specification?
fxnytro1050
Yes theres nothing wrong with my throttle. I was thinkin about puttin.wd40 or sonethin down the throttle cable to see if that would work.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
You dont wanna do that. Never spray inside the wires.. It will cause them to freeze.
If its up to spec i would get a tether, and disconnect the tors.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
Same prob on an apex couple weeks ago he by passed it and rode that day hooked it back up and it was fine
BigShow29
Mine rusted inside the plastic and would stick. I sprayed wd 40 down it and has worked good all season.
YamaMTX
- Feb 7, 2009
- crosslake MN
- 2009 Yamaha nytro and polaris 600 rush
How do you disconnect it? just went to load up for a trip and now mine is throughing code 84. I have a teather already.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
