Code flashing on apex
Darren Betker
Dryden
Canada
apex gt
Yellow light on my 06 rtx flashing continuously, engine wont go just above idle. Noticed just before it did it that when i reved up the engine the head lights were going dim at high rpm. Anyone know what this means
If there is a flashing yellow light there should be a code flashing as well, look it up in the Apex FAQ section at the top of the page. Have you added a handlebar riser or had the throttle bodies off? Almost sounds like the TORS is engaging. Either way the code should get you started in the right direction.
Like i said its a flashing yellow light. Constantly flashing. No pattern to illicit a code.....just constanly flashing.
If the light is flashing there will be a numbered code coming up on the display as well.
Well it stopped doing it as fast as it started. I believe it was an oil leak that sprayed on the thors and made it short out. Fixed now. Thanx guys
