Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Yellow light on my 06 rtx flashing continuously, engine wont go just above idle. Noticed just before it did it that when i reved up the engine the head lights were going dim at high rpm. Anyone know what this means
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
If there is a flashing yellow light there should be a code flashing as well, look it up in the Apex FAQ section at the top of the page. Have you added a handlebar riser or had the throttle bodies off? Almost sounds like the TORS is engaging. Either way the code should get you started in the right direction.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Like i said its a flashing yellow light. Constantly flashing. No pattern to illicit a code.....just constanly flashing.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
If the light is flashing there will be a numbered code coming up on the display as well.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Well it stopped doing it as fast as it started. I believe it was an oil leak that sprayed on the thors and made it short out. Fixed now. Thanx guys
