codes 33 & 36, new plugs, runs like crap or not at all
Whitehorse, yukon, canada
lookin for some help, my apex been sitting about 6 months, and i went to start it and it wont start. rolls over but wont fire so i put a new set of iridium cr9eix plugs in, and i disconected boondocker box so to eliminate some potential causes, i get codes 33 and 36 which would be cylinder 1 and 4 not firing, correct? i had it run once since i put in the new plugs. and i tried switching coils 1 into 2 cylinder and 3 and 4, still get code 33 and 36. sometimes it wont fire at all but backfires somethin fierce. makes you have to check your shorts (LOL) so any help would be appreciated what it could be thanx!
i cleaned all the wiring harness plugs and the coils and even switched #1 and 2 coils and #3 and 4 still get the same 33 and 36 codes which is #1 and 4 cylinder so shouldnt be the coils. :/ kind of a tough one
Is the wiring to the fuel injectos or coils swapped around at all? I had a similar issue and injector #4 harness was on #3, once I referenced the wiring manual I swapped them around and she fired up and purred.
